Thread: Bedini SG
  #284 (permalink)
Old 02-12-2008, 03:41 AM
ren's Avatar
ren ren is online now
Senior Member
Peper there are two things here that you and I are discussing. One is utilizing both sides of the electromagnet (coil) with twin rotary devices, the other is utilizing both sides of the magnet (a coil on either side of the rotary device). I'm not sure which one you are reffering to, both can be utilized. I think you should check out the diagrams on this page, particulary the adams motor configs on page 4.
http://www.panaceauniversity.org/Chapter2.pdf
There are so many configurations to test!
@ Gmeat. I have noticed better charging rates at higher amp draws too. However I think that each setup has an optimum efficiency draw. I guess theres a stage where you are pushing too much current into the charge battery.
