Thread: Bedini SG
  #275 (permalink)
Old 02-11-2008, 11:23 PM
ren's Avatar
ren ren is offline
Senior Member
Guys I think you are on track here, perhaps not in this thread but on to something none the less. I believe peper10's idea to utilize the other end of the electromagnet is similar to some of Johns G -Field designs. The easiest way to do something like this would be a design similar to this one.
Directory:Bedini SG:Replications:Monsieur Bonheur FluxGate - PESWiki
A central shaft could turn a pair of rotors with the coils mounted between. Heck you could gang ten rotors together and fill the gaps with coils.
If your e- magnet is pulsing and you are utilizing only one pole, then it makes sense to factor in the other end. Aaron showed a good little clip of a window coil winding with an led on the ends. When placed under an sg(?) motor coil it would light up.
