radiant:current ratio
At the higher frequency, I believe your voltage potential to current ratio is too high...slow it down and you increase the amount of current. You need enough current to get the battery into real charging mode. If the radiant is too pure at the higher frequencies, it will be a fluffy "static" charge.
I'm don't mean just charge with a lot of current...just enough.
