Old 09-08-2011, 08:15 PM
Slovenia Slovenia is offline
Gold Member
New Message from Contact
My Message to Contact Sept. 8, 2011:
Sept. 8, 2011
Things become much clearer to me now. I have a few questions to ask.
1). How do we get the iron band resonance at 400 Hz?
In your chart display 110-volt connection with a beer can on the left side of the diagram.
2). Beer can is a positive connection to 110 volts right?
3). Steel band connection is negative at 110 volts right?
4). Also, are there measures to protect the operator from electrical shock hazard?
5). Is your water tank is made ​​of conductive material does not?
Response from Contact:
Sept. 8, 2011
Excellent picture and you understand the draw.
Grounding is the entrance to the exit of water and boiler water from a plastic tube separated from the plastic that goes into the radiator. The voltage of 110 volts COP 12.460 times at 100 degrees Celsius ana 80 is eight times when well done. The distance between the electrodes should be to calculate because it is not the same as here in Europe. This is the hardest part to find the frequency of standing wave current of 60 Hertz. I can calculate that if you pay me.
