Old 08-23-2011, 12:36 AM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Platinum Member
Send a message via MSN to MonsieurM
Originally Posted by MonsieurM View Post
even simpler on page 5
The same authors found that even the dissolution of NaCl
in water produces & growth-stimulating radiation (Table 14) This
energy emission occurs only during the act oI dissolving ; it- ceases
completely when all the salt i8 in solution' No effect is noticeable
when sugar is dissolved in water, or when palmitic acid is dissolved
in alcohol. Wolff and Ras concluded therefore that the process
of dissociation of salt into ions is the source of ultraviolet'
truly this document is full of info that could be applied to the rest of the Electromagnetic Spectrum (principle of correspondence )
now salt water is Na+ Cl + H2O right and when it dissolves, the act of dissolving produces UV what follows
John Kanzius: RF-Induced Hyperthermia vs Cancer -- RF Ignition of Salt Water: US Patent Application # 0060190063
Salt Water-Fuel
Filling a test tube with salt water from a canal in his back yard, Kanzius placed the tube and a paper towel in the machine and turned it on. Suddenly, the paper towel ignited, lighting up the tube like it was a wax candle.
"Pretty neat, huh?" Kanzius asked WPBF's Jon Shainman.
Kanzius performed the experiment without the paper towel and got the same result -- the saltwater was actually burning.
and guess what:
Why does blood taste salty?
A sodium test checks how much sodium (an electrolyte and a mineral) is in the blood. Sodium is both an electrolyte and mineral. It helps keep the water (the amount of fluid inside and outside the body's cells) and electrolyte balance of the body. Sodium is also important in how nerves and muscles work.
Most of the sodium in the body (about 85% this number keeps popping up remember your brain has about 85% of water) is found in blood and lymph fluid. Sodium levels in the body are partly controlled by a hormone called aldosterone, which is made by the adrenal glands. Aldosterone levels tell the kidneys when to hold sodium in the body instead of passing it in the urine. (See a picture of the adrenal glands or the kidneys .) Small amounts of sodium are also lost through the skin when you sweat.
Sodium (Na) in Blood
if you allow me....heehee
rife machine Rife Beam Ray Machine Frequency List
For those who have been studying RIFE for many years now, how many remember the original claim relating to pleomorphics and the need for only 5 or 6 basic frequencies which RIFE said would kill any disease? It is quite similar to what Gaston Naessens claims but Rife preceded him though not using the same terminology.
now i understand, Rife beam ray modulates the wavelength of UV/infrared produced thanks to Na within your body to fight a particular disease.... (principle of cause and effect and principle of correspondence see post )
It would appear that the salt is still present in the water when it dissolves but in such small size particles that you cannot see them.
Bio-Frequency Spectrum (BFS) is a nomenclature for both the frequency and spectrum of physical information emanating from the living human body. BFS is different from the description of frequency and the spectrum of wave length. It has been found that the existence and changes of the physical information not only correlate with the functional status of the body itself, but also can reflect its healthy status. Experiments have confirmed that the living body is a natural irradiating source, which emits frequency signals into the environment continuously. In comparison with other irradiating sources, the energies are relatively weak. BFS in living bodies has common characteristics and its range of frequencies is from ultra-violet rays to weak microwave. However, BFS in the human body are mainly concentrated in the region between infrared to weak microwave. Simulating this comprehensive physical information of the body and feeding it back into the body constitutes the key points of BFS theory.
Bio-Frequency Spectrum (BFS) aka Biospectrum - Electronic Healing
Piezoelectricity ( /piˌeɪzoʊˌilɛkˈtrɪsɪti/) is the charge which accumulates in certain solid materials (notably crystals, certain ceramics, and biological matter such as bone, DNA and various proteins
-------Principle of Polarity
Riot control - Wikipedia, the free encyclopedia
Active denial systems (ADS) are a non-lethal, directed-energy weapon developed by the U.S. military. The ADS directs electromagnetic radiation, specifically, high-frequency microwave radiation, at a frequency of 95 GHz, which causes the water (which is salty ) in the upper epidermis to boil, stimulating a "burning" sensation in the nerve endings and generating intense pain.
Signs and symbols rule the world, not words nor laws. -Confucius.
