Old 08-12-2011, 06:13 PM
Xenomorph Xenomorph is offline
Silver Member
Originally Posted by zilano View Post
frequency downgrading: from khz to hz
u can use resistor or caps across secondary. but u must know voltage and amps for resistor so u can use proper wattage of resistor. if u using caps then u must know output voltage.
use page 23 of handbook of electronic tables book uploaded by me in one of my posts. there u find reactance chart.
WRONG
A lonely parallel resistor is not changing the frequency.
It is DRIVEN by the coil
Test it yourself, run a motor and use different parallel resistor values to one generator coil. Will that change the frequency you measure in the generator circuit across the resistor or the load?
Complete BS.
