  #549 (permalink)
Old 01-14-2008, 06:12 AM
twoody twoody is offline
Junior Member
Originally Posted by Peter Lindemann View Post
Twoody,
Welcome to the group. Excellent work so far. The model you are building will teach you the truth about many things. Each design, and every design feature, functions as a specific "question" you are asking of Nature. The behavior of the design is Nature's "answer" to your question. And Nature NEVER LIES!
Peter
Peter
I have completed my windings. and have wired the stator with two sets of 6 coils. Each set of 6 has a resestance of 1.4 ohms. When I use 24 volt imput and ark to the windings my roter will turn about 5 times. But I am having trouble with the transistors. When I use my slot optical switch and send a low voltage on the base, the transistor turns on but I do not see the full 24 volts through the collector to the emitter. I could see in your video you have a neon light would this help? I can get the roter to just barly turn when I use the transistor but it will not keep the rotor turning. I have tryed a 2n3055, TIP31, and a high voltage nte2594. would the use of larger wire and sodering all connections make the differance as in your motor demos on youtube?
