Originally Posted by theremart
Sigh,
Well I put 5 Coils firing on the wheel I attached to this generator, and I could not get it to turn  . I am seriously thinking about returning this generator...
The other option I have is to build a motor that uses very little power to turn this generator to achieve over unity,
Per say ->
http://www.geocities.com/koneheadx/32magnetrotor.html
Or, to build an alcohol still and use a lawnmower powered by the alcohol to turn the alternator to charge the batteries. ( this requires some serious travel and work )
The generator must only drag, when a load is attached to the output. If it does not turn without a load so easily then it must be an issue with poor design. It is very disappointing to see that you could not turn it with a five coil SSG.
