  #1 (permalink)
Old 04-29-2007, 01:38 AM
Jane Jane is offline
Support, PATHS, S.A.
PATHS- Module Discussion ~Change of Life Module
To help shed some light on the different PATHS Modules, and what they do, we will be posting the different Module descriptions in here so that you can share your experiences and ask any questions you may have about the Module. We look forward to your responses!
Reduces Pre-Menopausal & Menopausal symptoms
When menopause hits, there are many symptoms that can occur. Some of these symptoms are hot flashes, decreased sexual desire, mood swings, irregular bleeding, self-doubt, and memory problems.
With the Change of Life Module, these areas are addressed in a way to help eliminate the above negative aspects.
You will experience a calm mind and body, balancing of hormones, and feelings of happiness and confidence while you adjust to this new change.
Addressed:
- Stimulate ovary health
- Balance estrogen/progesterone/testosterone levels
- Calm physical body
- Increase serotonin production/absorption
- Increase calm feelings
- Increase all opioid peptide production/absorption
- Increased confidence
- Increased sexual desire
- Increased estrogen/progesterone production/absorption
Recommended Program Supplements:
- Spirulina for necessary Amino Acids
- Multi-Vitamin and Mineral Supplement
Recommended Duration of Use:
Change of Life Module requires continued used to receive consistent benefits. The biological instructions can only work while you are using the module, though many habit changes will keep lasting after only 60-90 days of use.
