Old 07-16-2011, 02:53 PM
IndianaBoys's Avatar
IndianaBoys IndianaBoys is offline
Silver Member
Ormus Is A Gas
MonsieurM,
That is good info.
Lots to digest.
What also came to mind with the experiments we did may connect to Ormus being a gas:
Periodic Spontaneous Energy Discharging From Neodymium Magnet - Zoom version
‪Periodic Spontaneous Energy Discharging From Neodymium Magnet - Zoom version‬‏ - YouTube
Energetic Fly By Zoomed In and Slowed Down 6X
‪Energetic Fly By Zoomed In and Slowed Down 6X‬‏ - YouTube
Energetic Fly By 2
‪Energetic Fly By 2‬‏ - YouTube
The phenomena you see in the videos i believe is related to the ormus gas John Milewski and David Hudson speak of. The components are heat (from focused halogen lamp of microscope), ferro fluid (nanoparticles of magnetite), quartz glass (ferro fluid is sandwiched between the high quality microscope slides).
Dr. Milweski has a process of using a microwave as a "furnace" and transition the ormus gas into noble metals.
Dr. John V. Milewski: Growing Gold from Glass in a Microwave - Part 1
‪Dr. John V. Milewski: Growing Gold from Glass in a Microwave - Part 1‬‏ - YouTube
ORMUS IS A GAS
ORMUS IS A GAS by John V. Milewski
We are postulating that the free atom Ormus form of these 13 transition atoms is a very chemically inert gas. We also postulate that they are very small in relation to their masses and are surrounded by a very strong antimagnetic field. As a result of these properties we suspect that our atmosphere contains a significant amount of these gases. If this is true we would expect them to blend into our atmosphere and be easily mistaken for other gases such as argon, nitrogen and CO2, which might have similar weight and vapor pressure.
In addition to existing as a gas and because of their small size and chemical inertness they would easily diffuse into matter both liquids and solids. It has been suggested that they are captured in water structures and in most crystal structures such as quartz, magnetite and marble just to name a few. We think that their antimagnetic field helps them stay centered in the electric and magnetic fields found in the lattice structure.
IndianaBoys
Originally Posted by MonsieurM View Post
