Thread: Bedini SG
Old 01-05-2008, 04:32 PM
elias's Avatar
elias elias is offline
Gold Member
Batteries are different
Originally Posted by geron View Post
What about using capacitors instead of battery?
Is there some reason, that they shouldn't work or miss important properties of a battery?
While they are not really appropriate collecting energy, they might give the advantage to have very soon a result of the efficiency of the bedinimachine.
Nearly the same we might have with small batteries (nickel cadmium or like that): if the one, which is driving the machine, is emptied within 5 or ten minutes while the other one is charged, we should get a much more precise result and may have many more testing cycles, than with bigger batteries.
Hi Geron,
In my oponion batteries are different from capacitors, although electrolytic capacitors are a bit similar to batteries, but batteries tend to behave rather non-linear and store charge rather differently. Capacitors are not like that.
I made that example for verification of how much energy is in the output of the system and different capacitors absorb different amount of energy. So different batteries can indeed "absorb" different amount of energy too, as Bedini has stated he uses four on the output.
Elias
