Old 07-04-2011, 08:15 PM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Platinum Member
Send a message via MSN to MonsieurM
also
Gravity Nullified
Quartz Crystals Charged by High frequency Currents Lose Their Weight
those willing to do some further research, here is a trick:
Although some remarkable achievements have been made with shortwave low power transmitters, radio experts and amateurs have recently decided that shortwave transmission had reached its ultimate and hat no vital improvement would be made in this line. A short time ago, however, two young European experimenters working with ultra-short waves, have made a discovery that promises to be of primary importance to the scientific world.
The discovery was made about six weeks ago in a newly established central laboratory of the Neuuartadline-Werke in Darreskein, Poland, by Dr Kowsky and Engineer Frost. While experimenting with the constants of very short waves, carried on by means of quartz resonators, a piece of quartz which was used, showed a clearly altered appearance. It was easily seen that in the center of the crystal, especially when a constant temperature not exceeding 10 C / 50 F was maintained, milky cloudiness appeared which gradually developed to complete opacity. The experiments of Dr Meissner, of the Telefunken Co,, along similar lines, according to which quartz crystals, subjected to high frequency currents clearly showed air currents which ld to the construction of little motor based on this principle. A week of eager experimenting finally led Dr Kowsky and Engineer Frost to the explanation of the phenomenon, and further experiments showed the unexpected possibilities for technical uses of the discovery.
Kowsky & Frost -- Gravity Nullification -- Science & Invention, Sept. 1927
remember this article i posted
Solar power without solar cells: A hidden magnetic effect of light could make it possible
Light has electric and magnetic components. Until now, scientists thought the effects of the magnetic field were so weak that they could be ignored. What Rand and his colleagues found is that at the right intensity, when light is traveling through a material that does not conduct electricity, the light field can generate magnetic effects that are 100 million times stronger than previously expected. Under these circumstances, the magnetic effects develop strength equivalent to a strong electric effect. from the article
doesn't it sound similar
Joel McCLAIN & Norman WOOTAN
The Magnetic Resonance Amplifier
With low-level ultrasonic input signals, the Magnetic Resonance Amplifier (MRA) produces usable direct current power at levels above unity. This circuit is based upon the work and theories of John Ernst Worrell Keely, and is offered into the public domain in his memory.
Introduction ~
Without lengthy discussion about the aether, tetrahedral geometric aggregate resonance or the Rule of Nines, it is possible to understand this circuit as basically a tuned magnetic and quartz amplifier..
Joel McClain & Norman Wootan: Magnetic Resonance Amplifier ~ Collected Papers
What is an ultrasound?
Ultrasound is a safe, painless diagnostic procedure that uses high-frequency sound waves to create images of organs and body structures.
for the piezoelectric property see also : Radiation pressure
Radiation pressure - Wikipedia, the free encyclopedia
Radiation pressure is the pressure exerted upon any surface exposed to electromagnetic radiation. If absorbed, the pressure is the power flux density divided by the speed of light. If the radiation is totally reflected, the radiation pressure is doubled. For example, the radiation of the Sun at the Earth has a power flux density of 1,370 W/m2, so the radiation pressure is 4.6 µPa (absorbed).
now you get the idea
