Old 07-03-2011, 09:40 PM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Platinum Member
Send a message via MSN to MonsieurM
I just wanted to add some info on a previous post:
Much Obliged IndianaBoys
Very interesting info, It is true that the use of crystal to help tune an oscillator maybe the fastest way of getting results. We do use quartz to run our watches, why not use other type of crystal to help tune a water coil
Short Description of Dowsing by Raymon Grace from Blue print for freedom video
YouTube - ‪Short Description of Dowsing by Raymon Grace from Blue print for freedom‬‏
Building a Field Broadcaster - Cosmic Pipe
http://www.acresusa.com/toolbox/repr...oilair0802.pdf
Contains plans on building a unit.
Farming the Atmosphere
http://www.acresusa.com/toolbox/repr...here_jun97.pdf
From: Harvesting Energy From the Sun Using Crystals
Solar power without solar cells: A hidden magnetic effect of light could make it possible
Light has electric and magnetic components. Until now, scientists thought the effects of the magnetic field were so weak that they could be ignored. What Rand and his colleagues found is that at the right intensity, when light is traveling through a material that does not conduct electricity, the light field can generate magnetic effects that are 100 million times stronger than previously expected. Under these circumstances, the magnetic effects develop strength equivalent to a strong electric effect. from the article
Quartz
Although quartz is not conductive (meaning it doesn't carry electricity like most metals such as copper), it has certain electrical properties that make it very useful for certain electronics. In particular, it is piezoelectric. "Piezoelectricity" is a word derived from the Greek word "piez" or "piezein", meaning "to press"; Piezoelectric materials are non-conductive materials which generate electricity when you subject them to pressure, and vice-versa: They undergo physical deformation when you run electricity through them. If you compressed a pice of quartz using a pair of pliers or a vise, it would generate a very small electrical charge, and if you connected a piece of quartz to either end of a battery, the crystal would bend or warp slightly. These effects are too small to be visible to the human eye; You won't actually see the crystal bending or shaking, and you won't notice sparks coming from it, but there will be very tiny effects, and these can be detected and used by electronic circuits.
Information on electronic quartz crystals
Quartz resonators consist of a piece of piezoelectric material precisely dimensioned and orientated with respect to the crystallographic axes. This wafer has one or more pairs of conductive electrodes, formed by vacuum evaporation. When an electric field is applied between the electrodes the piezoelectric effect excites the wafer into mechanical
vibration. Many different substances have been investigated as possible resonators, but for many years quartz has been the preferred medium for satisfying the needs for precise frequency generation. Compared to other resonators e.g. LC circuits, mechanical resonators, ceramic resonators and single crystal materials, the quartz resonator has proved to be superior by having a unique combination of properties. The material properties of quartz crystal are both extremely stable and highly repeatable. The
acoustic loss or internal fraction of quartz is particularly low, which results in a quartz resonator having an extremely high Q-factor.
The intrinsic Q of quartz is 107 at 1 MHz. Mounted resonators typically have Q factors ranging from tens of thousands to several hundred thousands, orders of magnitude better than the best LC circuits. The second key property is its frequency stability with respect to temperature variations....
...Modes of vibration, cuts and frequency ranges
The AT-cut resonator uses the thickness shear mode of vibration (fig.3). A standing wave is set up in the crystal blank by the reflection at both major surfaces of traverse waves travelling in the thickness direction. The major mechanical displacement is in the plane of the crystal at right angles to the direction of wave propagation. At resonance an odd number of half wave lengths are contained in the thickness plane of the crystal blank. Therefore the thickness is the primary frequency determining dimension.
http://www.scapro.se/text/jauchkristallara.pdf
also
Quartz Crystals
Electron Tubes by John Morecroft, 1933 starting page 334...
Fixing Frequency by Piezo-electric Crystal
Quartz Crystals
Signs and symbols rule the world, not words nor laws. -Confucius.
