Old 06-26-2011, 01:22 AM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Platinum Member
Send a message via MSN to MonsieurM
WATER AND THE SACRED (remember adaptive fractal antenna )
Water is a primordial element which underlays creation myths and stories around the world. The Egyptian Heliopolitan creation story recounts that the sun-god Atum (Re) reposed in the primordial ocean (Nun). In Assyro-Babylonian mythology, first the gods and subsequently all beings arose from the fusion of salt water (Tiamat) and sweet water (Apsu). The holy books of the Hindus explain that all the inhabitants of the earth emerged from the primordial sea. At the beginning of the Judeo-Christian story of creation, the spirit of God is described as stirring above the waters, and a few lines later, God creates a firmament in the midst of the waters to divide the waters (Genesis 1:1-6). In the Koran are the words We have created every living thing from water.
Sacred Places: Water and the Sacred
compare the two underlined sentences,
Originally Posted by arKzeRo View Post
This looks quite interesting!
Stanford researchers have developed a battery that takes advantage of the difference in salinity between freshwater and seawater to produce electricity.
Stanford researchers use river water and salty ocean water to generate electricity
Best Regards
Miller–Urey experiment
The Miller and Urey experiment[1] (or Urey–Miller experiment)[2] was an experiment that simulated hypothetical conditions thought at the time to be present on the early Earth, and tested for the occurrence of chemical origins of life. Specifically, the experiment tested Alexander Oparin's and J. B. S. Haldane's hypothesis that conditions on the primitive Earth favored chemical reactions that synthesized organic compounds from inorganic precursors. Considered to be the classic experiment on the origin of life, it was conducted in 1952[3] and published in 1953 by Stanley Miller and Harold Urey at the University of Chicago.[4][5][6]...
...The experiment used water (H2O), methane (CH4), ammonia (NH3), and hydrogen (H2). The chemicals were all sealed inside a sterile array of glass tubes and flasks connected in a loop, with one flask half-full of liquid water and another flask containing a pair of electrodes. The liquid water was heated to induce evaporation, sparks were fired between the electrodes to simulate lightning through the atmosphere and water vapor, and then the atmosphere was cooled again so that the water could condense and trickle back into the first flask in a continuous cycle.
Miller–Urey experiment - Wikipedia, the free encyclopedia
