Old 06-12-2011, 11:25 PM
Farmhand Farmhand is offline
Platinum Member
40 volt primary cap charge ?
Hi Cody, I have four new cap charge waveforms can you tell me if any of them is heading in the right direction.
Cap charge -1
Cap charge - 2
Cap charge - 3
Cap charge - 4
So this is where I'm at so far, I made a base for the receiver and moved it 10 or 12 feet from the transmitter, it seems to work much the same as when next to the other one but an actual ground connection shared between them seems to drain the power.
With all of those cap charge's I get between 40 to 70 volts on the receiver output but the frequency is different.. The LED lights quite brightly and I managed to find another 5mm white LED, but it blew too so I still only have one working white LED, it must be a good one.
