  #15 (permalink)
Old 06-09-2011, 08:34 PM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Senior Member
Send a message via MSN to MonsieurM
I found an intriguing information, and i was wondering if these frequencies couldn't be used in our water coil:
Fundamental Frequencies of the Earth and the Sun
We will now attempt to find the correlative basis for a number of significant octave relationships based on the terrestrial Schumann Resonance and the solar hydrogen-alpha fundamental frequency....
.... The Schumann Resonance consists of a “chord” of subaudible infrasound extreme low frequencies of the Earth itself resonating with the uppermost atmosphere. Its fundamental tone or tonic note
oscillates slightly around the frequency of 7.8 Hertz (cycles per second). It also has overtones that oscillate around the frequencies of 14, 21, 26, 33, 39, and 45 cycles per second.
.....The octaves of 7.8 Hertz are 15.6, 31.2, 62.4, 124.8, 249.6, 499.2, 998.4, 1996.8, 3993.6, and so on up through auditory sound and then into the electromagnetic spectrum....
.... The frequency of 14 has octaves of 28, 56, 112, 224, 448, 896, 1792, 3584, 7168
.... The sixth or highest generally reported Schumann overtone is 45 Hertz which has the octaves of 90, 180, 360, 720, 1440, 2880, 5760, 11520, 23040, and so forth.
Reminder
Resonance in water.
If you wind 1000 turns of 26 swg enamelled copper wire around a glass bottle filled with water and then flash this coil a cross a 12 volt car battery ..... all of the protons in the bottle, that were previously aligned with earths magnetic field .... immediately realign them selves with this new field. As soon as this field collapses the protons want to realign back to Earths magnetic field. The problem is that the protons are spinning like a top and instead of a smooth precession they 'wobble' back, in the same way as a child's top wobbles as it runs down. If after flashing the coil we then connect it to a high gain frequency counter we can actually measure the 'wobble' frequency ...... and it is directly proportional to the ambient field strength. For example in Southern England ... away from any magnetic anomalies ... the wobble frequency is about 2000 Hertz. If magnetic anomalies are present then the wobble frequency will change. This is the principle of the early magnetometers.
...Equipment resonance.
If we wire a capacitor and an inductance is series or parallel, together they form a tuned circuit, that has a resonant frequency. At resonance the voltage across the inductance or the water capacitor is at a maximum. If we want to develop a maximum voltage across either component then the frequency of stimulation must equal the resonant frequency of the tuned circuit, ie the water capacitor and two resonant chokes. At this point we have to assume that they really do form a tuned circuit. The next move is to excite that tuned circuit to find out what it's resonant frequency is. This has to be done with the water capacitor full of water, which has a dielectric constant of about 84. This means that providing the water does not short out the plates, the capacitor will have it's empty value multiplied by a factor of 84 ... since C approximates to .....
Where ....
C is the capacitance in farads, F
A is the area of each plate, measured in square metres
εr is the relative static permittivity (sometimes called the dielectric constant) of the material between the plates, (vacuum =1)
ε0 is the permittivity of free space where ε0 = 8.854x10-12 F/m
d is the separation between the plates, measured in metres
Searching for Magic Frequencies
An electrostatic spatial resonance model for coaxial helical structures with applications to the filamentous bacteriophages.
It is found that coaxial helices with optimally mated symmetries can lock into spatial resonance configurations that maximize their interaction. The resonances are represented as vectors in a discrete three-dimensional space[
http://www.ncbi.nlm.nih.gov/pmc/arti...00068-0079.pdf
