Old 06-09-2011, 02:04 PM
Farmhand Farmhand is offline
Platinum Member
I just had a thought.
Is there any reason I should not connect the negative of the primary to the negative of the secondary and ground ? Because if I do that I think I would be pumping a lot of energy into the ground.
I am collecting the collapsing field to charge another battery, but if I disconnect it the protection neon fire's, I think if I connect a ground there it will stop the neon fireing but that seems like a waste. Or is that part of the effect ?
Do I need to get higher voltage Mosfets so they can take the field collapse without a recovery battery or ground connection there ?
The charging of the second battery is very good with particular setup, but that is not the goal. It seems wrong to collect the collapsing field with this.
Any thoughts
