  #2 (permalink)
Old 12-18-2007, 12:22 PM
Jetijs's Avatar
Jetijs Jetijs is online now
Senior Member
Next I made the top cover plate of the electrolyser. This time I used a polycarbonate sheet 8mm in thickness. Polycarbonate is more dense and does not shatter or crack under any circumstances. Since there will be tension and pressure from the bolts that are holding the cover to the electrolyser, and the e will be some stress on the material form the 1/4" output thread, the plycarbonate is a way to go.
Here you can see two separate compartments assembled with plates.
I haven't finished this electrolyser yet, but I will keep you informed about my progress in this field. I am going to test how it behaves if powered with my 6 coil SSG, what will be the gas production difference form an ordinary power supply. Also I have an regulated 30V, 20A PSU that I can use to prove if it is indeed true that the voltage does not matter, but the current does
So if you have any comments or suggestions, you are welcome
Jetijs
