Thread: Radiant Energy
  #38 (permalink)
Old 12-16-2007, 09:34 PM
Aaron's Avatar
Aaron Aaron is online now
Spiritual Entrepreneur
radiant energy, longitudinal wave, spirituality and consciousness
Originally Posted by Schpankme View Post
Aaron,
How does your 'concept' of Radiant Energy compare with Longitudinal waves ?
What does spirituality and consciousness have to do with Radiant Energy ?
- Schpankme
Hi,
The potential or voltage potential is the radiant part and if we can direct it without closing the loop and causing "electron current" to flow, then it travels longitudinally. It is instantaneous transfer from one "place" to another "place."
The body and it's nervous system operates on longitudinal impulses. When you feel something by touching it with your finger, your brain is registering it BEFORE you actually touch it so that there is a time delay taken into account so that you have sensation of touching it in live time. The sensory information is sent to your finger before you actually touch it to give the impression that everything is in time. This is a superluminal time-reversal phenomenon.
Below the belly and in front of the spine, there is a capacitor that holds about 80% of our on board life force potential and the other 20% is being utilized by normal functioning. In Chinese, that capacitor is called the Dan Tien or the "Sea of Qi." Qi, Ki, Prana, Breath of Life, Life Force, etc... are exactly radiant energy...it is the virtual photon potential of vacuum space/time. The subconscious mind operates from the spine near this area and there is a lot of grey and white matter exactly like what is in the brain. This is where the "gut feeling" comes from.
None of the electrical action in the body comes from the chemicals, etc... When there is a chemical action in the body in a cell for example to pump in certain nutrients and pump out others, the chemical action is essentially causing a dipole effect to break the symmetry of the potential in its vicinity in order to cause the potential to move causing "electrical action."
Radiant Energy is the potential is the life force energy
A capacitor can hold a certain amount of the radiant gas and so can the body
Also as living organisms - human beings - are open non-equilibrium thermodynamic systems, we also have open access to a constant influx of potential to replace any potential dissipated from work done by us.
The infinite sea in 3d time/space filled with infinite potential...the infinite potential is what makes up the collective unconscious mind. It is a recording medium that maintains our memory. Our memory is not stored in our brain but in the collective/matrix itself. For each connection made in our brain, it is a known variable in the collective what piece of data that connection corresponds to in the collective. If the memory was in our brain, there would be nothing that carries on when we die and I believe there is, because it isn't recorded by anything physical.
Technical Remote Viewing quantifiable proves beyond a shadow of a doubt that we can access info that isn't in our brain but that resides in the collective... you can see some of my older practice sessions here to see what I mean... I had no idea was I was viewing until after I was done. The data comes out pretty raw.
basic trv sessions
Also Bearden's Radionics-Action at a Distance video he discusses a lot of this. There is one case of a man who graduated with a degree in mathematics in the UK. He had no brain in his head...totally water and not much more than a brain stem.
With spirituality, lessening our individual conscious thinking mind so that we are more in a state of pure being (like were were before our judgment mind perceived that we are an individual personality separate from God - the original sin in my opinion). This is one of my main personal spiritual goals. Becoming one with the infinite potential basically.
I know I went on some tangents. My 2nd book that I'm about 30% done with (before editing) focuses more on the mind/consciousness/synchronicity, etc... and how it all ties back to the concepts in the first one that spells out what the potential is.
Anyway, I hope that helps a bit.
