Old 04-02-2011, 11:52 AM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Platinum Member
Send a message via MSN to MonsieurM
Joel STERNHEIMER: DNA Music
When we think of plants being affected by sunlight we are really looking at the effect of a portion of the electromagnetic spectrum on plants that portion which includes visible light. It should not surprise us that sound also impacts plant growth because it is, in essence, an extension to other parts of the electromagnetic spectrum.
More on This:
Joel Sternheimer -- Protein Music -- French Patent # 2,136,737
found new info, it goes as follows:
Tszyan KAN'CHZHEN: Microwave Transfer of Biological Information
Tszyan Kanchgen has lead a series of experiments, which have shown an opportunity of direct transfer of the information from one biological object to another by radio waves [45]. Tszyan Kanchgen has created installation [46], including hollow correct of polyhedron and hollow cones located on its sides. The biological object which is carrying out influence is located in a cavity of polyhedron, its the radiations amplify and are transferred to other alive object by microwaves.
In experiments with cereal cultures Tszyan Kanchgen placed in the installation green weight of wheat and influenced by radio waves on germinate sabadillas of corn. The "processed" corn had set of lateral stalks. On the place of panicle the original ears with grains similar and on corn, and on wheaten (fig. 26) were formed. The acquired new qualities were steadily transferred to the subsequent generations.
more on this:
Tszyan Kanchzhen
some more info:
Three Soviet scientists, S. STSCHURIN, V. P. and L. KAZNACHEJEU Michailova, confirmed after more
than 5 000 experiments that living cells transmit information through photons (in 1981).
We can describe the experiments simply as follows:
- Cells are bathed in a nutrient solution in two spherical flasks made of quartz. The two flasks are touching
each other
. If a cell culture is affected by a virus, or poisoned, the cells in the adjacent flask become
impaired every time and always have the same symptoms, whereas they should be protected from the toxic
influence of other cells by the quartz side
s.
- If you use glass flasks, the second cell colony is protected.
- The transmission between the two colonies is made by ultraviolet radiation.
*** These same three Soviet scientists measured the cell radiation using a photomultiplier. "Normally living
cells emit a constant stream of light rays. When a virus enters cells, radiation changes: it first increases -
then silence then new increase, then gradual attenuation of radiation in multiple wavesuntil the cell
dies. This recalls the cries of pain of an animal.
*** In 1974, Simon STSCHURIN, said: "The cells affected by different diseases have different radiation
characteristics. We are convinced that photons are able to inform us long before the onset of pernicious
degeneration to disclose the presence of a virus ".
Today, scientists worldwide are exploring this phenomenon:
- In Australia, the correlation between cancer and ultra-hight- throuhput radiation is under study.
- In Brazil, fundamental studies are being conducted to understand light transport in cells.
- In China, the action of light on cells is currently studied.
- In Japan, research is trying to make an early diagnosis of cancer from cell radiation
Quartz + Water are key here also
link:
Light biology - quetanglais
more on info found here:
Biophysics And the Life Process
Russian student develops method to diagnose early cancer: Voice of Russia
