Old 04-02-2011, 11:42 AM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Platinum Member
Send a message via MSN to MonsieurM
now unto our Nobel Price Winner:
Luc MONTAGNIER DNA Teleportation
A Nobel Prize winning biologist has ignited controversy after publishing details of an experiment in which a fragment of DNA appeared to 'teleport' or imprint itself between test tubes.
According to a team headed by Luc Montagnier, previously known for his work on HIV and AIDS, two test tubes, one of which contained a tiny piece of bacterial DNA, the other pure water, were surrounded by a weak electromagnetic field of 7Hz.
Eighteen hours later, after DNA amplification using a polymerase chain reaction, as if by magic the DNA was detectable in the test tube containing pure water.
note: looks to me that a zone of activation was created then the dna transfer was accomplished
and also the weak electromagnetic field of 7Hz used is actually close to Schumann resonances:
The Schumann resonances (SR) are a set of spectrum peaks in the extremely low frequency (ELF) portion of the Earth's electromagnetic field spectrum. Schumann resonances are global electromagnetic resonances, excited by lightning discharges in the cavity formed by the Earth's surface and the ionosphere.... distinct peaks at extremely low frequencies (ELF) around 7.83, 14.3, 20.8, 27.3 and 33.8 Hz.
makes you wonder...
side note:
Originally Posted by MonsieurM View Post maybe a link with the earth's resonance and a clue to our evolution (hope i am not going too far in saying this )
it is also one more clue to nature as having a fractal antenna properties, adding to it the same resonance of two identical coils (ie: the water)
just like Tesla's Experiment
Will two identical coils be in resonance with each other?
"Quantum Water" Discovered in Carbon Nanotubes
Chengdu Organic Chemicals Co. Ltd., Chinese Academy of Sciences
A new quantum state of water found in carbon nanotubes at room temperature could have important implications for life...
...That's a big deal. Reiter and co chose carbon nanotubes because they are an analogue of the conditions water faces when passing through living systems, through ion channels in cell membranes, for example. Biologists have long known that flow through these channels is orders of magnitude greater than conventional fluid dynamics predicts. Perhaps this new state of quantum water is the reason why.
to read more on this:
Luc Montagnier -- DNA Teleportation -- article & patent application
Schumann resonances - Wikipedia, the free encyclopedia
Update: After some Research Thanks Dave45 , Quartz + Water are key here in the Transfer of Dna
see:Harvesting Energy From the Sun Using Crystals
Next up: DNA Music
