  #43 (permalink)
Old 04-25-2007, 10:16 PM
nali2001 nali2001 is offline
Member
To Lindemann
Hallo Peter,
I have seen your video and find it a positive product and thank you for your input in this field. I know there are a lot more people to be thankful of like Bedini but this one is directed at you.
Anyway I like the Teal concept only the whole mechanical wear and tear of the pistons kind of bothers me. I mean a combustion motor can at least use oil to lubricate the pistons. Also I believe it will be quite noisy. But anyway I was kind of surprised when I saw in the video your ‘flux motor’ now the geometry was kind of familiar to me because I have tried in the past to build Ecklin-brown style variable reluctance generators. They were all made with great care. All made out of laminated material from microwave oven transformers. Machined to size, and each laminate reinsulated and reassembled. Only problem is that I never nearly managed to get the output levels described in this document.
fluxgate generator
But I did not know that you did something along these lines. Now I don’t know what your results were but mine were not really promising. The most I could get out of the best device is like 15 watt. But on the positive side, the thing is not really bothered by Lenz Law, since the coil and magnet are both stationary. And if you test the device and load the output coil the thing actually goes way up in rpm, which is of course the opposite if compared with normal generators which require more input torque once loaded. But like I said my output was ‘nothing’ and had much magnetic cogging and was noisy and all. But on your old picture I see quite some light bulbs so I presume you were getting a good amount out.
But back to the flux motor. I like this design. But you don’t tell much about it in the video. So what were the results? You mentioned on the audio interview that you got speed problems which limited the design to like 500 rpm? Was this due to your switching system or due to the slowness of the steel? Since the steel needs a given time to fully build up and relax again. And although some people thing this is neglectable I must point out that this IS a problem and I have seen it in more devices. Anyway here are some pics of my machines. (Note 00.jpg is not my system)
http://home.planet.nl/~sintt000/pics/00.jpg
http://home.planet.nl/~sintt000/pics/01.jpg
http://home.planet.nl/~sintt000/pics/02.jpg
http://home.planet.nl/~sintt000/pics/03.jpg
http://home.planet.nl/~sintt000/pics/04.jpg
Steven
