  #39 (permalink)
Old 04-25-2007, 03:27 PM
k4zep k4zep is offline
Junior Member
Teal Motor More Thought
Hi Gang,
Reading all the above post it is obvious that the basics of the Teal motor is understood. Peter very clearly showed most of the basics that the motor requires to run and has discovered the secret of the enclosed solenoid field process that increases the output.
If anyone looked at the photo of my motor they will see all the attributes Peter has suggested for a successful motor including very close/closed coupling of the solenoid piston and coil. That is mandatory or the motor is a pip squeek with very low output.
What Peter has missed or has not shown is the effect of a pulse that is of a VERY HIGH POTENTIAL (hence high peak current in coil) and the effect it has on the output of the motor when all of the energy of the pulse is contained in the solenoid!. If you make a L/C circuit out of the solenoid coil and a cap which holds the basic power for one pulse, add a diode across the coil to capture any back emf IN THE COIL, pulse the cap into the coil for a VERY short time at anywhere from 600-1000 VDC, the motor turns into a power house! The LCD of the motor/cap/diode network turns into a PFN network that results in the single high voltage/current pulse and the diode helps kill the ringing.
The easiest way to SEE this effect is to take a 24VDC industrial relay, which basically has an enclosed field in the coil and movable armature. Place a HV diode (1000V at least, 1N4007) across it (this stops the ringing, keeps energy in the coil/solenoid and as it is NOT polarity sensitive, any current in the coil in either direction pulls it in!), observe polarity when you do the next step. Key it with 24 volts observe it's "clunk" as it pulls in, normal operation. Then charge a 1uf HV cap (at least 2000V rating) up to 24 V, remove from supply and connect it across it, keeping polarity right. Nothing happens. Keep going up in voltage, around 80-90 VDC, it will start pulling in weakly. Around 250 VDC it will clunk pretty well. Around 5-600VDC, it will BANG in, around 800-1000VDC it will almost tear the armature off as the Cap. discharges in less than 1-3ms. Another secret is the old Amp/Turns field here, VERY HIGH CURRENT PULSE, LOTS OF TURNS IN COIL=POWER pulse. There is a lot more going on here but that is the basics. The Joules stored in a cap as voltage goes up and the Amp/turns formula I believe result in a non linear output effect. Any higher than about 1000VDC, the coil insulation will start to break down. Due to the contained field, for some reason, you can pulse much higher voltages into the coil and not have a breakdown, I do not know why this happens but it does. If you look at the waveform at 800-1000VDC, you will see a perfect square 3-600us pulse with virtually no ringing (.5v max) as all the back emf is sucked back into the coil and USED. All the above works with a solenoid as in my motor too! I built the motor 6 months or so ago while playing around with GRAY motor theory and was not aware of the TEAL motor at that time. To make a motor of this type run, you simply add the mechanics, a power supply to charge up the cap. between pulses and a timing/firing device. Nothing new, just application of observations from that darn relay.
OH a word of warning, 1000VDC and 1UF will kill you if you get across it. BE VERY CAREFUL.....!!!!!!!!
Respectfully,
Ben
