Thanks, I hadn't seen the first one which simulates the O2 sensor, the other two I have seen. They are the circuits I mentioned above that ADD a voltage to the O2 sensor output to lean out the mixture. Neither of the latter are what you would want if using the antifouling spacer. These and their complexity are what the spacer allows you to avoid. - Scott
