  #16 (permalink)
Old 11-23-2007, 03:54 AM
Aaron's Avatar
Aaron Aaron is offline
Spiritual Entrepreneur
o2 sensor points
The more I learn the more I realize I don't know. I like to take this stance too.
I understand the oxygen influence in a very basic way in relation to the o2 sensor. Little oxygen = rich so it leans the mixture out. Lots of oxygen = lean so it richens the mixture up.
I don't understand the temperature connection very well except that it seems that it needs to be at "normal" operating temp to do its job.
The non-fouler mod will definitely reduce the amount of oxygen getting to the sensor to lean it out. However, the spacer will also most likely reduce the temperature of the sensor as well so how does this really effect it?
Less oxygen so it will lean the mixture using less gas but lower temp will richen back up and break even so no point? That is the two things I see here in conflict with this modification potentially.
Everything I read about this sensor mod is for the 2nd o2 sensor with removal of the catalytic converter, etc... and not for fuel mileage increase. Just that hydrogen website selling the non-foulers as a solution for what I want to accomplish with it...keep the mixture leaner.
The temp thing may be further complicated with the RXP Generation II additive because it causes the exhaust to be lower anyway because of radiant containment methodology and more thorough burning so less heat & less emissions.
If I need more heat in the sensor, I will add my nasa ceramic paint additive to some high temp paint and paint it on the non-fouler spacers and the outside of the o2 sensor and that WILL lock in more temp.
A steam pipe at 400 degrees outside temp dropped to 200 just by being painted with the ceramic additive so this is what I will do if necessary.
No matter what is supposed to happen, often it becomes apparent that real world experience sometimes contradicts what we think will happen and this makes it necessary to actually do the experiment.
After I get through a few tanks, I'll know if I'm using more or less gas and that should answer the fuel mixture question if it does what is supposed to happen. If there is pre-detonation that is undetectable by sound, etc..., I'm sure I can tell by looking at the plugs to see if there is evidence of that. I have NOT looked at the plugs currently to even be able to compare but I may.
Also, the 14.7:1 mixture is also an ideal mixture for a simple spark as far as I understand. With a true burst of plasma like Firestorm plugs, there is enough energy there to fully combust a lean mixture up to 40:1 for practical use and even 100:1 for demo purposes...so it also has to take in to account what is contributing to the release of the mixture lean or not.
