Old 11-19-2007, 08:35 PM
Aaron's Avatar
Aaron Aaron is offline
Co-Founder & Moderator
eec
Yes, but through the H2Earth's chatroom etc,... they're saying Dave Lawton used it with his water cell to light the 40watt bulb. Did Dave not really do this or did he only have it hooked up above the water through another tube setup that only the gases were going through?
It has been said pretty clearly by them that it is connected to the tubes submerged in water. Conceptually, it seems it would work on submerged tubes as well. Under an electron cascade effect, the EEC should conceptually pull a lot of those electrons to the pos plate and to the bulb to be burned. Then there is even more separation in the water itself.
If it doesn't work in water then I don't have to waste time with it at this point but if simple enough to try, would be interesting to see results.
