  #16 (permalink)
Old 11-15-2007, 08:38 AM
Aaron's Avatar
Aaron Aaron is online now
Spiritual Entrepreneur
self runner
Hi Ren,
You can charge a cap and charge a batt from an SSG diode at the same time but would dilute each of the results. I would recommend experimenting with an isolated winding.
On the self runner, I have had similar concepts increase the front battery voltage, but I must warn you that if there isn't enough current, which has been my experience and only pure radiant back to the input, the voltage will climb but the battery will get damaged. You need the bare minimum amount of electron current to put the battery in charging mode. Also, the battery gets goofy if you try to alternate the charging and powering modes like this. They like to either power constantly or be charged constantly for a while but not flopping back and forth. It is a good demo to see the possibilities and a better way to do it and is a good learning experience but I wouldn't say it will be good for practical use and I don't think Rick is claiming it is a practical way to do it either but I could be wrong.
