Old 12-28-2010, 07:56 PM
Jetijs's Avatar
Jetijs Jetijs is offline
Gold Member
Guruji,
Yes, you need energy to heat the reactor, but if you do that using electricity, you will only need around 8 cents worth of electricity per liter of fuel, that is cheap. And it gets even cheaper if you use liquid fuel burner to heat the reactor and use the produced fuel for heating. We calculated that such a setup would consume around 7% of its produced yield, but now this thing is self sustaining and you only need to get some plastic I wouldn't bother with solar for reasons I already mentioned:
I am not sure about solar, probably not a good idea as the heat source is no reliable, as you get the heat up, you don't want it to drop considerably until the process is finished, because that would solidify all the melted plastic into a big blob and this would the take forever to remelt. Solar would probably work on very small quantities.
