Old 12-27-2010, 10:33 PM
Jetijs's Avatar
Jetijs Jetijs is offline
Gold Member
Originally Posted by bugler View Post
Thanks.
Where is the info shared? Is there a website or file?
How do you make the coils and power them?
What is the tap above the machine?
Would it be possible to see a more detailed diagram with all parts?
Thanks.
The basic info is shared in this topic, experienced builders should already have all the info to replicate. I will elaborate more about the construction.
The white inner rings in the metal drum are made out or about 50 aluminum oxide bricks. I use aluminum oxide because it is light weight and easily cut, like foam. So you cut them so that they make a circle. There are grooves cut in them to house the heating coils. The coils were bought from a kiln making company, you just tell them your power needs, voltages and other stuff and they give you nichrome wire in needed length and diameter, you just need to wind it on a round stick to form a coil and then insert in those grooves in aluminum oxide bricks. Our device has six coils rated for 1kW each, so 6 kW total heating power. I use three phase current, six coils are connected in 3 parallel pairs, a pair for each phase. They are switched on and off using three solid state relays that are controlled by a digital thermostat. The thermocouple is located on the lid of the reactor. There is a metal cage in the barrel that keeps the reactor container apart from the bricks and coils. You just slide the reactor container in, bolt the lid on and connect the condensing reservoirs and off you go. The pipe from the lid goes through three condensing containers, but there could just as well be only one. The plastic melts and boils in the reactor, the vapors go to the condensing container where it cools down and most part of the vapors turn into liquid, remaining vapors that contain mostly gas go through a safety bubbler which catches the last bits of fuel leaving only gas, that you can burn. There usually is very little fuel in the bubbler after the process, and it foats on tor of water and can be easy removed.
Hope this helps,
If you have any other questions, don't hesitate to ask
