Originally Posted by lighty
@Jetijs
I noticed a strange vibrating sound when your motor is in operation. Something is not balanced or not centered correctly or with low enough tolerance.
Did you consider using another base plate and another bearing so that you can have a 2 point shaft support? You can then use self-centering axial-radial bearing at one side to compensate for eventual lateral movements. I have had experience building powerful motor from scratch and one point support of shaft is simply too unreliable for the forces involved. Especially with pulse motors.
Nevertheless - a GREAT work pal!
if you check the commutator side you can see that he does have two bearings on there, still I think you may be right adding another bearing, but i would place it on top, where there is none at the moment. Or is that what you actually meant?
Also I doubt whether all the noise is coming from the bearings. Tweaking the timing a little bit might also decrease noise.
