  #14 (permalink)
Old 11-04-2007, 10:16 AM
Mario's Avatar
Mario Mario is offline
Member
SS oscillator
Originally Posted by Ewhaz View Post
Well, I'm getting my components ready for assembly finally. I'm purchasing components now, based on the Solid state oscillator in bedini's free energy generation book.
The only thing I'm having difficulty on is that some of the components do not list a voltage, such as the discharging capacitor on the charging side. What should that be?
Also.. I've been wondering for a long time now, why doesn't Bedini use timers etc for his oscillation? It seems strange that he is always using the coils field to create the resonance, is there a reason for this?
If it is necessary to get optimum EM field characteristics then I can understand, however if it is not needed... Well then that would reduce the number of wires to a coil by 1.. Or leave you with one more charging output line.
Hi Ewhaz,
The transistor part number in the book is wrong and should be BD243C, another mistake is pin 4 and 5 of the opto, the connections are inverted.
I have tried running the oscillator from a 555 instead of the trigger wire, it works too, but for every freq you are tuning to you have to readjust the duty cycle to get the best signal for that freq, finally I found that the trigger winding does this automatically and even better , so I went back to the winding.
regards,
Mario
