  #14 (permalink)
Old 11-03-2007, 04:38 PM
dyetalon's Avatar
dyetalon dyetalon is offline
Junior Member
Originally Posted by adam ant View Post
not on the lens itself, the housing or base of the unit. in the PDF file there is a photo which (unclearly) shows some sort of metallic container or device on the bottom. corrct me if i am wrong.
There is no metal supporting the lens, or encasing it. I'm not sure what you see, but it may be the support bracket for the incandescent lamp I used for illumination.
The test jig I used for capturing this image consists of a PVC ring painted flat black that supports the lens, and it's mounted on a movable stage (up-down) like an optical microscope uses. Below the lens assembly is another PVC housing painted black that the light source is contained in. The mounting hardware is brass and aluminum (non-ferrous).
I can upload the test jig on my server for you to view, if you desire- and provide a link to it here.
