Thread: Bedini SG
  #44 (permalink)
Old 10-21-2007, 01:39 PM
Ted Ewert Ted Ewert is online now
Member
Originally Posted by Shamus View Post
Thanks Kevin, for that note of encouragement. I've taken pictures of the 4-pole monopole and will post them soon. As for my feelings of frustration, part of it has to do with Peter's revelation vis-a-vis the Bedini pedulum. All that work for naught. The other part of it is this: I think I have found at least part of an answer as to why I'm running up against brick walls here. Personally, I think he's only partially right; I think he's missing a lot of the picture with respect to the mass scale conditioning that most people are subject to here in the U.S. and in most European countries. People who are brought up to be sheep aren't going to make wise choices, you know? I don't know if it's just a blind spot or willful, but it only adds to my frustration to see attitudes like that--and probably explains why good information is so hard to come by.
OK, enough sermonizing. I'm sure nobody really cares to hear such things anyway, so I'll shuddap about it already.
Right now I've got the 4-pole monopole (I think I'll call it a 4PM ) with 2.2K base resistors just to see how long it will take to get the battery up to, say, 15V or so. Just to see what will happen. I'm pretty sure I know what will happen with 330 base resistors (faster charging, higher current draw ). I'm not sure how John Bedini got 24V showing up on the charging battery side with this machine (I'm still getting only around 12V with spot measurements)--I'm sure that even if I had eight coils like he has on his that I'd still be seeing only 12V on mine. Ah well, c'est la vie. Ours is only to know in part, I suppose.
I will say that this machine does develop some torque though--probably due to the fact that it fires twice as much as a machine with all its coils aligned with the rotor magnets. You could probably develop even more torque with the coils suitably arranged.
At any rate, the next machine will definitely be an n-filer coil with multiple recovery circuits. BTW Kevin, I'll be interested in seeing the results of your tests with your "non-superpole-superpole" magnet arrangement. Also, be sure to keep us posted on your progress with the big machine.
Hi Shamus,
I feel your pain man! After having high expectations of my first few Bedini machines I was "underwhelmed" with their performance (to put it mildly).
However, I have come to realize that this was not a result of the machine, but rather due to my lack of understanding.
Batteries need a combination of current, pulse rate, pulse amplitude and impedance matching to optimally charge. Radiant energy is developed in a number of places, but is really only part of the total picture.
I don't pretend to be any kind of an expert with these types of machines, but I have pulled my hair out long enough to see how much more I have to learn. The process is frustrating and difficult at times but the payback is in knowledge. Experimenting with different charge rates and voltages will be very revealing in figuring out how your machine runs best.
Multi coil machines will definitely draw more current than the single coil ones. I wouldn't worry about that so much right now. Figure out where it charges best by doing some full charge cycles on some batteries. Put a bunch of batteries in parallel and see how that works.
Each machine is different and will take a while to get to know. Your machine has an optimal setup which will give you much better results than you are seeing now. It just takes some patience and perseverance to find it.
Cheers,
Ted
