Thread: Bedini SG
  #43 (permalink)
Old 10-21-2007, 05:20 AM
Peter Lindemann Peter Lindemann is offline
Senior Member
How can I help?
Originally Posted by Shamus View Post
Thanks Kevin, for that note of encouragement. I've taken pictures of the 4-pole monopole and will post them soon. As for my feelings of frustration, part of it has to do with Peter's revelation vis-a-vis the Bedini pedulum. All that work for naught. The other part of it is this: I think I have found at least part of an answer as to why I'm running up against brick walls here. Personally, I think he's only partially right; I think he's missing a lot of the picture with respect to the mass scale conditioning that most people are subject to here in the U.S. and in most European countries. People who are brought up to be sheep aren't going to make wise choices, you know? I don't know if it's just a blind spot or willful, but it only adds to my frustration to see attitudes like that--and probably explains why good information is so hard to come by.
OK, enough sermonizing. I'm sure nobody really cares to hear such things anyway, so I'll shuddap about it already.
Right now I've got the 4-pole monopole (I think I'll call it a 4PM ) with 2.2K base resistors just to see how long it will take to get the battery up to, say, 15V or so. Just to see what will happen. I'm pretty sure I know what will happen with 330 base resistors (faster charging, higher current draw ). I'm not sure how John Bedini got 24V showing up on the charging battery side with this machine (I'm still getting only around 12V with spot measurements)--I'm sure that even if I had eight coils like he has on his that I'd still be seeing only 12V on mine. Ah well, c'est la vie. Ours is only to know in part, I suppose.
I will say that this machine does develop some torque though--probably due to the fact that it fires twice as much as a machine with all its coils aligned with the rotor magnets. You could probably develop even more torque with the coils suitably arranged.
At any rate, the next machine will definitely be an n-filer coil with multiple recovery circuits. BTW Kevin, I'll be interested in seeing the results of your tests with your "non-superpole-superpole" magnet arrangement. Also, be sure to keep us posted on your progress with the big machine.
Shamus,
No one thinks you are whining. There is a lot of confusion out there. I worked for Energenx when all of the larger rotating machines were built. All of the big machines, the 12 coil machine with the barrel rotor, the 10 coil machine with the large black rotor, the 6 coil machine with the silver rotor, were 24 volt systems! You will never duplicate what these machines do with a 12 volt system.
These machines can be seen on this page.
20 Bedini
Look at the batteries. The picture of the large round batteries on the floor. They are 1600 amp-hour 2 volt cells, 12 of them wired in series. Look at the copper buss-bars connecting the batteries in series. The systems were connected to the control box with 00 (two aught) wire. This is a super LOW IMPEDANCE system. Total resistance of the whole battery bank was .002 Ohms! Due to these conditions, the Radiant Energy behaves differently.
Every one of these machines was slightly different. Every machine was designed to TEST something specific. The variations being tested were the CONFIDENTIAL property of Energenx and its stockholders. A lot of information has been published, but a lot has not. That's business. Like I said, millions of dollars of investor's money has been spent developing these systems:
Energenx, Inc.
I'm interested to know why you think I am "only partially right". What do you mean by this? I am painfully aware of the how ill-prepared most people are to understand what John says or what Tom Bearden says, or what I say. There is not much we can do about that. The fact is, Energenx is a Public Stock company. Information was only published about systems that have no commercial value. The method of operation of the products on the products page above is TOTALLY DIFFERENT than anything you know about. It doesn't mean what has been published is worthless. It means John LEARNED something from these stepping stones and the designs progressed.
Please don't be upset about all of this. It's business. What you have learned about this is SOLELY due to the fact that John is a generous humanitarian who honestly cares about the world. He was under no obligation to tell anyone anything about what was learned at the expense of his investors!
Keep experimenting with your models. John gave you the place to start. But now you have to learn how to learn. Let the machine tell you it's secrets. They're right in front of you.
Best wishes,
Peter
