Nice pics
Peter,
I spent all the time today figuring out how to solve the problem with my startor. There were several ideas that would require to build a mechanical device to solve this problem. Lastly I figured that I could just make a template of the startor plates with a hole in the exact center of the rotor. Then I could attach this template to the startor piece so that the tempate edges and corners lines up exactly like the startor edges and corners. This way I will have the exact point of refference to adjust my selfmade cnc milling machine. So I made the template out of a 3mm thick aluminum plate so that it matches the tartor plates exactly in dimensions.
Now I have to attach this plate to the startor so that the edges are in perfect alignment. Then I will just move the endmill bit of my router to the little hole in the startor so that the endmill bit fits right in the hole. Then I will zero out all axis and this will be my X 0; Y 0 point. Now I will just have to replace the endmill bit to a suitable one and let my router go in circles, each time making the circle a tinny bit bigger
What do you think?
