  #67 (permalink)
Old 10-17-2007, 11:54 PM
Grace's Avatar
Grace Grace is offline
Ordained Consciousness Science Ambassador
Send a message via Skype™ to Grace
Cool The Master Cleanser by Burroughs
Originally Posted by adam ant View Post
Grace:
from the Master CLeanse
the mample syrup is only an energy source for this ten day cleanse. the lime/lemon is extremely acidic and could agitate ulcers, stomach lining, weaken teeth, and ENHANCE any forms of disease, cancer, bacteria etc. These things LOVE acidic solutions. the sea salt cleanse is much more alkaline and has all of the colloidals you need for energy in perfect balance. plus, it is only 24 hours, not 10 days (yuk!!)
Hi Bryan,
I definitely benefited from "The Master Cleanser" fast. I was on it for 10 days and it did more for me than when I was on a watered down juice fast for 14 days. I have tried different types of fasting since I was in my late 20's and the Master Cleanser has been the easiest and most beneficial to me so far. I exercised while on the Master Cleanse, and carried on with life in the same way without much difference. I did make sure I got extra sleep as suggested but I didn't feel tired! I also did not feel hungry. I just missed the joy of chewing!
Here is an excerpt from the book "The Master Cleanser" by Stanley Burroughs
Is the Lemonade Diet Also a Reducing Diet?
As a reducing diet it is superior in every way to any other system because it dissolves and eliminates all types of fatty tissue. Fat melts away at the rate of about two pounds a day for most persons, and without any harmful side effects.
All mucus diseases such as colds, flu, asthma, hay fever, sinus and bronchial troubles are rapidly dissolved and eliminated from the body, leaving the user free from the varied allergies which cause difficult breathing and clogging of the sinus cavities. Allergies exist as a result of an accumulation of these toxins and they vanish as we cleanse our body. People who are over-weight often experience these difficulties, and the more they continue to eat the toxic fat producing foods which cause their obesity, the more their other ailments multiply.
Mucus disorders are brought about by the eating or drinking of mucus-forming foods. In other words, if you have these diseases, YOU ATE THEM! As we stop feeding our family mucus-forming foods, we can eliminate their mucus and allergy diseases for the rest of their lives.
The types of disease which are a result of calcium deposits in the joints, muscles, cells and glands are readily dissolved and removed from the body. Cholesterol deposits in the arteries and veins also respond to the magic cleansing power of the lemonade diet.
All skin disorders also disappear as the rest of the body is cleansed. boils, abscesses, carbuncles, and pimples all come under this category. These conditions are, again, Nature's effort to eliminate poisons quickly from the body.
All types of infections are the result of these vast accumulations of poisons being dissolved and burned or oxidized to produce further cleansing of the body. Therefore, rapid elimination of the toxins relieves the need for infectious fevers of all kinds. Infections are not "caught" they are created by Nature to assist in burning our surplus wastes.
Yes, the lemonade diet is a reducing diet, BUT MUCH MORE. Just as many other disorders also cleared up at the same time when it was used to heal ulcers, when it is used as a reducing diet, other ailments are also corrected in the process.
People build strong, healthy bodies from the correct foods or they build diseased bodies from incorrect foods. When disease does become necessary, the lemonade diet will prove its superior cleansing and building ability.
Here is his version of the Sea Salt Cleanse which he calls "Internal Salt Water Bathing":
This is a superior method to cleansing the colonic tract without harmful effects. This method will cleanse the entire digestive tract.
DIRECTIONS:
Prepare a full quart of luke-warm water and add two level teaspoons of uniodized sea salt. Do not use ordinary iodized salt as it will not work properly. Drink the entire quart of salt and water first thing in the morning. This must be taken on an empty stomach. The salt and water will not separate but will stay intact and quickly and thoroughly wash the entire tract in about one hour. Several Eliminations will likely occur. The salt water has the same specific gravity as the blood, hence the kidneys cannot pick up the water and the blood cannot pick up the salt. This may be taken as often as needed for proper washing of the entire digestive system.
If the salt water does not work the first time, try adding a little more or a little less salt until the proper balance is found; or possibly take extra water with or without salt. This often increases the activity. Remember, it can do no harm at any time. The colon needs a good washing, but do it the natural way - the salt water way.
It is quite advisable to take the herb tea laxative (smooth moves by traditional medicinals is the one I used) at night to loosen, then the salt water each morning to wash it out. If for some reason the salt water cannot be taken in the morning, then the herb laxative tea must be taken night and morning.
CLICK ON THIS FOR AN ARTICLE ABOUT THE SECOND BRAIN - THE STOMACH!
