Thanks Peter,
I cant wait to see the pictures although I understand what you are meaning. I have now some other problems. The guys from the machine shop said that the startor plates are glued together forming kind a cone. I you imagine the startor piece and see at it from the thickness side then it would appear something loke this:
|======/ |===rotor===| \======|
I hope you understand. The upper startor plates are closer to each other by about 0.2mm. This means that the top rotor plates will be closer to the startor piece than the bottom ones. This is not good and I have to figure out how to deal with it, because they cant do the lathe work if the startor isn't right and they do not have the equipment to fix the startor. I already have some thoughts, but this will take time.
