Originally Posted by Bit's-n-Bytes
Ok Matt you made me do it. Here is a peek at what I have been working on in an effort to do what you are talking about, as well as LENZ avoidance. It's not perfected. Thanks to Vissie and John Koorn for there input. As John calls it, "The Wilson Coil". As for the construction, the inner coil is 22awg or 5 ohms (still seeing where the optimum is) wound with the "Right hand Rule" to be able to "pulse" the SG. Then the outer coil is (still in expermintation, i.e. 5 filiar, single conductor) wound the "Opposite" direction, filling the remaining space. The inner coil is pulsed from the 2 Cap pulser which accomplishes several things. The first being a pulse to drive the SG, the second is to use a very low input current (500ma) and deliver a 1.5 - 3 amp output pulse, and the third is to create a "very sharp" transiate FLUX (the hidden energy) to influence the "outer" coil. With the outer coil being wound "opposite" early tests are showing a slight amplifying effect on the transient spike and during any current draw on this coil, is actually assisting the pulse "north pole" repulsion. Ok, that extruded some gray matter energy  With now a huge transient spike getting delivered to a cap for storage, Viola!, we now have a way to "close the loop" (wihout really closing the loop) if you know what I mean.
Food for thought.
Jeff
Quick, put the cat back in the bag
I didn't get much time to play with the coil yesterday Jeff, too busy restoring a 6V starter battery with the 2 cap pulser
John K.
