why?
EVERY part of sea salt is necessary, it contains within itself ALL of the necessary buffers, colloidals, and elements in PERFECT proportions. any form of processing in any way is like compairing aspirin to willow bark... willow bark is the natural form of aspirin but because of the natural buffers, there are NO side effects. (pure aspirin burns the stomach lining)
Amigo:
Damien is correct, solar evapoated sea salt refers to the method of drying the salt. Celtic Sea Salt is the number 2 choice, but if you look at the british coastlines, the Celtic drying facilities are down stream of some major sewage processing plants. it also has high sand silicates due to the proximity to the shoreline.
De Souza is the only company i have found so far that actually sails out 50 miles away from shore, and drops lines at least 200Feet down. this avoids ALL of the silicates and any possible human contamination. then they simply fill large vats with the water and let it dry in the sun. THAT IS ALL!!!
Jetijs:
salt is any metal that is combined with a halogen. (chlorine, iodine, flouride etc.,)
sea salt to me is the only REAL salt. sodium chloride is the same as aspirin to me... poison. sea salt, on the other hand, is like natures perfect vitamin.
why stop at AUM??? again, there is a full "spectrum" or chanting frequencies out there (harmonics) OOOOM(like in open), AAAAAM(like aim), UUUUM(like you), IIIIIM(like I'm), EEEEM(like steam)
just like the high vowel sounds... and you can also use the lower vowel sounds sounds oooom(like doom), aaaaam(like stan), uuuuum(like thumb), iiiiim(like imp), and eeeeeem(like
ever)
vary your pitch, find your harmonic octaves... you will feel it in your sphenoidal bone (HINT!!!!!!!!!)
if anyone can come up with the significance of the sphenoidal bone, then i will drop another bone.(google will only help a tiny bit) hahahahahaha
