  #34 (permalink)
Old 10-11-2007, 11:51 PM
Kevin's Avatar
Kevin Kevin is offline
Energetic Science Practitioner
Originally Posted by Shamus View Post
@Kevin: I've been meaning to ask: Is your setup the one that uses capacitors for charging on the back end, and are you able to swap batteries from the back end to the front end if it isn't (i.e., more or less stock SSG)?
I do not use capacitors, and perhaps I should not rotate my batteries from what has been said here.
Since we can measure the work leaving the primary battery with traditional measuring devices, I have never really cared how fast they discharged (though they do not seem to discharge unreasonably fast). What I have always been much more concerned with is the comparison of the work used to power the unit and the work the charging batteries are able to produce as a result.
As a side note-for over a year I was in a living situation where I had to position a wireless repeater in a location where there was no electrical outlet. I used deep cycle marine batteries and an inverter. Prior to using batteries charged with my unit, they were lasting about 2 days between conventional charges. When I started using the same batteries (not the same model, but the EXACT SAME Batteries) that had been charged and conditioned with my SG unit, they last 4-4.5 days between charges.
