rdt
Hi Danny,
As we go about our day, our subconscious takes in quite a bit of info. My belief is that "new" data or at least "new to my conscious mind" is connected to my own morphogenetic field of Aaron's collective database and the data will be attached to the proper associations (file cabinets).
When we dream, supposedly some of the dream process is our mind sorting out what was absorbed throughout the day so where is it stored for later processing? In the collective...in Aaron's folder...in Aaron's electronic engineering folder...in Aaron's EE folder in regards to magnets... for example if I took in info in regards to magnets in relation to some motors or something.
The PATHS instructions are stored in the same way because there is no way for the brain to process it all in live time. It doesn't do it all in live time with smaller amounts of info and certainly it will not do it with the amount of instructions PATHS technology is based on.
The holosync quote may need clarification. The PATHS technology is intended to give the mind a certain amount of info for the brain to process over the course of about 1 week. The binaural type soundtracks are intended to be used daily because the mind is only given small bits of information compared to PATHS. This is what I mean by it only working while listening to it. The binaural beats of course will only work while listening to it and the affirmations or whatever you want to call them will be stored in the mind for processing but so small amount of info compared to PATHS that it is needed daily.
Personally, I do not believe memory resides in the brain. Memory is in the collective for each person "history." The brain creates connections that have a certain chemical/electrical action that corresponds and is assigned to different info in the collective. When we "remember" something, those connections are retrieving the info from the collective based on its own associated piece of info and not because the memory is internal in the physical brain.
When remembering something in the past, the conscious mind is bilocating to the actual experience in the past, literally time traveling and in my opinion, the accuracy of that memory will depend on one thing. How present was someone in the moment during an event in their "past?" The more present in the moment, the more info is absorbed per unit of time and therefore makes for more accurate "memories." If not very present, then the memory won't be very clear.
In early testing to my understanding, based on when someone watched the theater one time, the effects of the instructions seemed to hold for about 1 week so I believe that is where the 1 week guideline came from. This seemed to be the average for most people testing for most of the modules a couple years ago. Many people say they get better results watching at least 2-3 times per week so that is what I usually recommend.
Some people watch 3 times a day 7 days a week. Can it be too much? No, because the absorption of info is self regulated. It will take what it can and the rest will spill over the glass.
Also, if you are familiar with QXCI or Core Inergetix technologies, they operate on quantum principles. Princeton university proved that the conscious mind can influence random event generators. Also, hardware can also emit signals into "subspace," which can be picked up by the subconscious mind. They operate on frequencies..each remedy has a frequency, etc...
Every single PATHS account has a certain amount of hardware allocated to it. This "booster" is running off and on 7 days a week emitting these instructions into "subspace" or "vacuum space" and the subconscious mind has the ability to receive this. This booster is a secondary component to the main theater presentation. This is why PATHS is so powerful and nothing else seems to be able to do what PATHS can do. The PATHS hardware boosters do NOT operate based on sending out frequencies. It is a proprietary principle used only by PATHS and no other company in the world has been able to figure out how they do it and probably won't for a long time.
