  #8 (permalink)
Old 10-09-2007, 09:53 AM
elias's Avatar
elias elias is offline
Senior Member
Somthing is definitely missing
Hi,
As I pointed out in my post "Flow of Radiant Energy" We should first understand what part of the circuit actually is responsible for this charging effect Bedini talks about. What role do the magnets play in triggering the radiant? I mean what is the advantage of the SSG circuit for charging batteries in relation to a simple dc/dc converter (charge pump)? the only difference is the magnets on the wheel. So do the magnets induce radiant energy to the the coil?
I personally think that Bedini has not told the principles in operation clearly. I watched the energy from the vacuum 2 and I watched it over and over to see if I could figure out what Bedini is talking about.
At last I could not understand where this radiant is triggered? I know that sharp gradients trigger this event but which sharp gradient is actually producing this effect?
1- The Magnets passing over the coil?
2- The collapsing field of the coil?
3- The sharp discharge into the battery?
Bedini talks about all three of these in the video.
I have personally concluded that the radiant is triggered each time but we could not capture all of it unless some unknown parameters are set right which Bedini has not pointed out clearly.
It would be better if Bedini came over and explained the more fundamental principles regarding the triggering and capturing of radiant energy in SSG, as he is the inventor.
I say this with all the respect I have towards John Bedini.
Elias
