  #12 (permalink)
Old 04-17-2007, 06:17 AM
Peter Lindemann Peter Lindemann is offline
Senior Member
Originally Posted by Eric View Post
lol now for a funny question. in the dvd you mentioned this idea is not overunity but... if as in your example a 1 hp motor might only use 30watts and 1hp equates to 746 watts ideally. doesnt this mean i could strap on a belt driven alternator to the shaft and deliver say 35 or 40 watts and still have slightly less than than 1hp of mechanical energy to use elsewhere making this a self sustaining motor? or am i missing something in the concept of unity.
thank again!
Eric
Eric,
Yes, you are missing something. The idea of efficiency is based on the First Law of Thermodynamics, often referred to as the Law of the Conservation of Energy. This idea is that energy can be converted from one form to another, but it is neither created nor destroyed by its passage through the mechanism. I do not believe in the idea of "Over Unity" because this Law is either correct and in-force at all times, or it is not. So, it is logical that the Law cannot be both correct and in-force, AND violated at the same time. It is well established that the energy conversion rate for the direct induction machine is 746 watts = 1 horse power = 550 foot-pounds per second of mechanical energy.
The magnetic attraction motors that my DVD discusses can be called indirect induction machines, as they use direct induction for the creation of a magnetic field, but it is the magnetic field that causes the mechanical energy production. So, the electricity input is only indirectly related to the production of mechanical energy in the machine. I have postulated that this process, which is NOT the same process as Faraday's induction, operates at a different conversion rate, somewhere around 200 watts = 1 horse power = 550 foot-pounds per second of mechanical energy.
Then, by configuring the machine to operate on short pulses of DC current, an inductor can be charged with electric current. This in turn, causes the creation of a magnetic field. As this magnetic field grows, it can be used to attract a piece of iron, producing mechanical energy. When the field is maximized, the current can be shut off, and the magnetic field will collapse. The collapse of the magnetic field will induce a new current of electricity that can be recaptured by the circuitry, and re-applied to the battery system, thus recovering up to 90% of the input electrical energy. If the machine can produce more than 10% mechanical energy production, then there is an anomaly here which needs a creative explanation.
So, the issue here is, how much mechanical energy can be produced by this process? The answer is, quite a lot, if you design the machine correctly. Way over 10%, in fact. So, when all of these processes are designed right, the machine apparently produces significant amounts of energy that are not explained by the Laws of Conservation.
So, three possibilities exist to explain this. The first is, that the Law of Conservation is just plain wrong, and nothing is being converted into anything else in any of these machines. Most people are not willing to entertain this idea. The second is, that the conversion rate for the indirect induction machine is different than for the direct induction machine, and therefore it can produce more mechanical energy from less electricity because that's what it does. Again, most people find this idea difficult to accept. The third is, that the machine is somehow tapping an unseen source of energy and converting it to the seen energy surplus. Many scientists are starting to consider this idea as the explanation for these phenomena.
No matter which explanation you pick, OVER UNITY is NOT one of the possibilities.
Does this help?
Peter
