Old 06-20-2010, 02:51 PM
Bit's-n-Bytes's Avatar
Bit's-n-Bytes Bit's-n-Bytes is offline
Silver Member
Send a message via Skype™ to Bit's-n-Bytes
Originally Posted by Matthew Jones View Post
I'll take a look at it. Do you have the specs (or a guess) or wire type on that coil. The dumps closed today so I am fresh out of junk microwaves. LOL.
@Bytes
What kinda transformer are you using? I wanna take a look at driving one also.
Matt
@John, @Matt, here is the parts list;
1n4001-Q1 1n4001
1n4001-Q3 1n4001
C1 0.33uf
C2 0.1uf
C3 35,000uf 35V
Cap-Q1 1.0uf
Cap-Q3 1.0uf
D1 1N5408
D2 1N5408
D3 STPS8H100D
D12 1N5408
DB9
J1
J2
J3
LED1 Yellow
LED2 Yellow
Q1 MJL21194
Q2 MJL21194
Q3 MJL21194
Q4 MJL21194
Q5 MJL21194
Q6 MJL21194
Q7 MJL21194
Q8 MJL21194
R2 10k 1/2 Watt
R3 10k 1/4 Watt
R4 22k 1/4 Watt
R5 330R 1/4 Watt
R6 330R 1/4 Watt
SW1 Reset E28
T1 273-1365A (Radio Shack)
U1 PICAXE-18X
U3 LM7805
U-Q1 H11d1
U-Q3 H11d1
Z2 1N4744A
The output is AC so disregard the + - (carry over from other designs)
The input is 12V only AC or DC.
Add or Remove MJL's Q5,Q6,Q7,Q8 for increase or decrease in power rating.
The transformer noted here is 0.45A, so you'll need to subsitute with others as necessary.
Here is the code for the chip;
Main:
high 7
pause 10
low 7
high 6
pause 10
low 6
goto Main
Adjusting the delay down increases freq's.
Enjoy,
Jeff
